4l65 issue
Old Sep 10, 2023 | 08:36 AM
bbull's Avatar
Default 4l65 issue
. I have 2 issues started at the same time
#1 the transmission is in reverse when in park (no not the linkage) in park the engine is loaded like it is in gear. When I shift out of park, as soon as the parking pawl releases it is already in reverse.
#2 happened at about the same time, I now suddenly have engine braking in every gear when the shifter is in the OD position
Old Sep 11, 2023 | 10:42 PM
vorteciroc's Avatar
If your Linkage and all corresponding Parts are good and aligned properly...
Then most likely you are going to need a Valve-Body, as it seem that the Manual Valve is leaking fluid through it's Bore in the different Gear Selector Positions.
