Th350c
Old Sep 23, 2023 | 09:34 AM
firefighter0677's Avatar
Default Th350c
Thanks in advance. Trying to figure out why th350c won’t shift into 3rd after I did ls swap in truck? no kick down cable installed. Actually it’s fully engaged by use of fishing sinker. Anyways. Lil background. 81 squarebody Just got done with ls1 swap and it won’t shift in drive. Only manually and still won’t shift into 3rd. Fluid and filter change Had a 350 in truck and trans worked fine. Any ideas to point me in to start?
Old Sep 23, 2023 | 11:01 AM
bbond105's Avatar
"Actually, it’s fully engaged by use of fishing sinker." What is fully engaged? Did you hook the modulator valve up to manifold vacuum?
Old Sep 23, 2023 | 12:54 PM
Yes mod is hooked up to vacuum on ls1 intake. And meaning I pulled kickdown cable on the end as far as it would move out and clipped a sinker on the sure to stop it from coming back in. Also changed gears in rear end to 373 and had to change flywheel so I had to disconnect shift rod. Could adjustment just be out on linkage? Doesn’t make sense cause it worked fine with the 350sb
Old Sep 23, 2023 | 03:28 PM
tayto's Avatar
verify the linkage is setup correctly who knows what you did during the swap. maybe the transmission is further ahead or further back depending on the engine mounts you used? maybe the pointer on the truck isnt set right
Old Sep 23, 2023 | 05:49 PM
vorteciroc's Avatar
If it is fully pulled/ engaged, there can be no Up-Shift to 3rd-Gear.
Old Sep 23, 2023 | 07:56 PM
Default Thanks
Appreciate everyone’s input. Suggestions. Pulled mod hose and tranny fluid was dripping from mod. Changed out and shifts perfect. Once again thanks everyone
