Flywheel for 6.0
Old Nov 18, 2023 | 09:37 PM
67camaro*'s Avatar
Default Flywheel for 6.0
I have a 5.3 Flywheel, does anyone know if it will work on this 6.0 LQ4 swap with a 4L60E?
Thank you, Eric
Old Nov 19, 2023 | 10:14 AM
performabuilt's Avatar
LS1Tech Sponsor
Yes It will work, dished side goes away from the trans. starter is the same, Just remove the crank spacer if applicable on the LQ4 because it is only used for the 4L80E
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
