AT 6L80 deeper pan
Old Nov 19, 2023 | 10:48 PM
PlymouthBarracuda's Avatar
Question AT 6L80 deeper pan
Maybe somebody knows, can I use the same oil filter if I replace my oil pan to the deeper one 24297104 ?
What is the difference between filters 24236931 (stock) and 24236933 (Escalade 2007-2014, Silverado 1500 2009-2013) ?
As I know, I will need a "wide-mouth filter", but what part number is ? Maybe the 24236933 is exactly what I need ?
Old Nov 20, 2023 | 10:00 AM
performabuilt's Avatar
LS1Tech Sponsor
They interchange and one part number usually references a kit. Im 99 percent sure this is the filter you want below. I dont know much more about the 6L in regard to this because i just started working on them so maybe someone else can double verify. I do know your only goal when using a deeper pan is - the filter must touch the bottom of the pan at all times.
24236933 inlet is bigger, can't tell the difference outside of that
Pan gasket
24224781
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 20, 2023 | 08:45 PM
Pan gasket
24224781
I hope that 24236933 inlet will fit the transmission mounting tube.
Thanks a lot
