What to do to make converter feel tighter
its a built 4l60 mated to a lq9 with 112/118 cam with .500 lift and 112 lsa
I have 3.42 gears on it
what would I have to do
it’s also about 2600-2800 stall
With the stock shift points I would be in 4th at like 35 mph at low throttle and until fast enough for lockup it would feel like was slipping like hell in 3rd and 4th particularly.
My converter is a 9.5 inch 2800 FTI TRIPLE DISC.
I have a 5000 stall now, custom built (yes, a little more $$) and you would never know it just tolling around. Now whether you're cruising around or launching from a dead stop...jumps straight to 5000-5200 and the fun starts.
Frank makes a good point as well. I upped my part throttle shift points when the first converter went in and have kept them there. OP may want to try that first if you have tuning capability, before going to the expense and hassle of purchasing and installing another converter.
That said, a better quality converter will give you better performance, longer life, and peace of mind regarding potential failure.
