408 with tall crank flange
Old Jan 2, 2024 | 07:55 PM
vern6.0's Avatar
Default 408 with tall crank flange
I have a 408 with a lunati crank. I noticed it when I had buttoned it up the front and rear covers that the crank flange was taller. I have a 4l80e trans but my converter will have 3 bolts and not 6. Who makes a sfi flexplate for tall crank flange that's flat for 3 bolts torque converter pattern
Old Jan 3, 2024 | 09:06 AM
MaroonMonsterLS1's Avatar
any flat flexplate for LS that would normally be used with a spacer...can be used here.
Just omit the spacer
All the spacer does is make the "short" cranks identical in length to your "long" crank
Also...it's a bit odd that lunati would make a crank with the long flange...check the stickies for good info showing pictures and measurements differentiating the short from long cranks
