05 k2500 4l80 stall shift kit help
Old Mar 29, 2024 | 08:48 PM
Cherrybomb's Avatar
Default 05 k2500 4l80 stall shift kit help
Hi all,
I just picked up a 05 k2500HD 6.0/4l80/4x4 excabsb. On 33’s with 4.10 gears.
It has longtubes 1 3/4”, and a Howards Rattler low lift cam. Gigantic cold air intake also.
The trans is currently out of it. I have a good trans to go in it, but its stock. I feel like I should at least put in a shift improver/valve body kit and “maybe” a stall? I have read the stock converter will stall at 2400, is that enough for this cam?
i bought this truck for my son, who just got out of the Marines, he wants to start a pressure washing business, so it will be dragging around a 6000lb water buffalo/pressure washer. As well as just rompin around I’m sure.
I dont have a ton of money for this, im just trying to do whats best for what the combo already is. Im not looking to change the cam out, or anything else. Just get the trans done and get it on the road. So maybe $175 for the shift kit, can I get a good enough converter for this application for a couple hundred bucks?
Thanks guys!
cam specs:
Summit Racing Part Number:
HRS-198035-09
UPC:
840793133659
Cam Style:
Hydraulic roller, OE roller
Camshaft Use:
Street
Camshaft Manufacturers Description:
Choppy idle, high performance street, stock converter ok, best with 1800+ stall and gears.
Basic Operating RPM Range:
2,200-6,500
Intake Duration at 050 inch Lift:
226
Exhaust Duration at 050 inch Lift:
234
226 int./234 exh.
Advertised Intake Duration:
275
Advertised Exhaust Duration:
282
Advertised Duration:
275 int./282 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:
0.525 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:
0.525 in.
0.525 int./0.525 exh.
Lobe Separation (degrees):
109
Remanufactured:
No
Computer-Controlled Compatible:
No
Valve Springs Required:
No
Old Mar 30, 2024 | 10:51 AM
FranksCustomTrans's Avatar
LS1Tech Sponsor
Originally Posted by Cherrybomb
Hi all,
Thanks guys!
Reman converter from WITS arround that price or from rock auto, As for shift kit if you are used to working with mechanical I would say for home novice with good mechanical experience and ability to read and follow instructions the Transgo SK kit https://www.jegs.com/i/Wilkins+Motor...YaApDuEALw_wcB probably be fine, I would not attempt the HD kits unless you are more familiar. First however I would pull pan and see if clean if it dirty or have silver/gold in it do nothing get a rebuild or replacement unit. Honestly GOOD 4L80E units in a junk yard are not as common as you might think, These things came in expensive trucks people do not discard them unless they are totaled or worn slap out with every possible mile run out of them. This is why when I buy cores for parts I generally ask for broken case cores as they tend to have the best parts in them.
__________________
Old Mar 30, 2024 | 06:47 PM
Cherrybomb's Avatar
I have rebuilt trans before, but never a 80. I do have the pan off right now on the bench, just waiting for the best advice on HD2 or not. Then button it back up and stab the converter and get it on the road.
Old Mar 30, 2024 | 07:01 PM
LS1Tech Sponsor
Well if you have the HD kit fine it deos require some going into trans beyond vb to do it all. If I was gonna buy something I would just do the SK kit which should do all you need for what you said you wanted to accomplish . Just My opinion.
__________________
Old Mar 30, 2024 | 10:21 PM
Cherrybomb's Avatar
Appreciate it FCT, that sounds solid. I have not purchased the HD kit yet, so I’m not opposed to the SK.
