4l60e 2-3 flare..
Old Apr 3, 2024 | 07:49 PM
98 blkmamba's Avatar
Default 4l60e 2-3 flare..
Transmission has had a 2-3 flare since built, builder went back threw it and still has flare. Builder is a reputable builder, I'm on the fence to goin to a 80e because I don't want extra weight..Anyone has any suggestions on this? Or has anyone dealt with this ?
Old Apr 3, 2024 | 08:45 PM
vorteciroc's Avatar
Just curious...
How many Pounds (Lbs) do you think a 4L80E Swap (From 4L60E) would add to a Vehicle on Average?
Old Apr 3, 2024 | 08:49 PM
vorteciroc's Avatar
Did your Builder provide you the Transmission Build Specifications?
The Separator Plate Orifice Sizes, and the Clutch Pack/ Band Clearances will be needed in order to discuss your Transmission.
Old Apr 3, 2024 | 09:03 PM
FranksCustomTrans's Avatar
LS1Tech Sponsor
Its likely Hydraulic however , Do not forget this , I actually ran into this twice over the years. https://www.sonnax.com/tech_resource...a-bad-computer
__________________
Old Apr 4, 2024 | 12:05 AM
bbond105's Avatar
I have had 2-3 flare when using the Sonnax Servo Release Check Valve in conjunction with a TransGo HD shift kit. Pulled it out and flare went away. I have not tried the Sonnax check valve with only a Sonnax kit to say if it was compatibility issue with the TransGo kit or the check valve itself.
As said above separator plate orifice sizes, clutch pack and band clearances along with hydraulic integrity are crucial.
Old Apr 4, 2024 | 09:01 AM
LS1Tech Sponsor
I will get crap for this lol but I dont really care for the sonnax "Quick release" check valve. Maybe because I dont really understand function at least as far as quick part.
__________________
Old Apr 4, 2024 | 08:27 PM
bbond105's Avatar
It didn't work for me.
