4l80e Not Move in reverse and drive
Old May 5, 2024 | 07:43 PM
alejandro.k320's Avatar
Default 4l80e Not Move in reverse and drive
Hello, I had a question to see if you could help me, I have a 4l80e transmission, I repaired it in reverse and it does not move as soon as it is applied, it tries to move and it skids but in 3, 2 and 1 when I select them it works fine. thank you
Old May 7, 2024 | 08:39 AM
MaroonMonsterLS1's Avatar
input sprag is damaged or installed wrong. Or you replaced it with the wrong variety (there are 2 different types)
in 3/2/1 the overrun clutch is "doing the job" of the input sprag
Need to teardown and correct
