GM246 Transfer case upgraydd
Old May 16, 2024 | 03:31 PM
Full Power's Avatar
Default GM246 Transfer case upgraydd
In process of installing a 4L80 in half ton suburban, so I have to change the INPUT spline shaft on 246 T-Case.
Disassembling the case, the rear magnesium case half is PRISTINE, beautiful. Zero debris on pump pickup filter. Magnet is clean.
Rear case pump locating spring clip is intact, shows NO wear and ZERO contact wear from pump thrust face.
the question is :
SHOULD I rip out the fragile spring clip, and install steel "case saver" in an other wise perfect case half... or just replace the input spline shaft, new seals, orings and glue it back together as is ?.
simply restated: Should I install Case-Saver or NOT ?
. Second question, on the subject : Is there much difference between the BLUE Auto-Trak fluid and DexronVI ?
Definitely drained OUT clean Red ATF from this case.
Old May 16, 2024 | 04:41 PM
Kfxguy's Avatar
ABSOFREAKINGLUTELY put the case saver in. You can use regular Dexron (like what you use in a 4l60) transmission fluid, but I take it a step further an use Honda ATF dw1 in my son's or any transfer case I build. Bout the only other upgrade i know of is a 6 pinion planetary. My son busted his 4 and I put a 6 in it. I also add a half quart of Lucas oil stabilizer to it. Thats just my preference. Does it help? Meh, I dunno. It seems to make it more quiet and less chunky.
I'd change the shift fork pads too.
Old May 17, 2024 | 11:10 AM
MaroonMonsterLS1's Avatar
Agree
YES to the case saver
I've always had good luck with Dex VI
I'd add a new magnet to your list as well as replace both the drain and fill plugs with magnetic versions.
And use the RTV sparingly...it doesn't take much. Any excess usually just ends up in the darn pickup screen and then slows oil flow
Old May 17, 2024 | 02:48 PM
Kfxguy's Avatar
Originally Posted by MaroonMonsterLS1
Agree
Aint that the truth!
I put brass plugs in because the aluminum ones suck (had to fight one out night before last!) but magnetic ones sound like a good idea.
Old May 17, 2024 | 11:24 PM
vorteciroc's Avatar
NO RTV... Too Thick!
Use a thin layer of Anaerobic Sealant on each side/ surface.
No Goop on the inside of the Case.
Old May 18, 2024 | 07:32 AM
Kfxguy's Avatar
I use hondabond
Old May 21, 2024 | 02:00 PM
vorteciroc's Avatar
Hondabond is most likely the absolute best RTV for one thing...
Problematic Joints that will not seal well (especially between different Metals or poorly machined Parts).
It Seals up Leaks amazingly!
It's pretty bad at removal/ clean-up on rebuilding.
Old May 21, 2024 | 02:51 PM
Kfxguy's Avatar
I agree. It’s hard to get it off! But I get loads of it for free. The techs give me all I ask for. So I use it ALOT.
 Michael S. Palmer
