Coupler Block
They are more of an Isolator/ Damper than anything else.
They must be used to assemble everything correctly or the Drive-Shaft will not connect.
They are #20.
Be careful if you start making good Power:
If the above occurs... there are Solid replacements (Metal), but all there will be no damped Harmonics or Vibrations.
They are #20.
Number 1 in the Image below:
Shown during disassembly below:
