C-5 filter
Old Jun 8, 2024 | 06:01 PM
Mark Vincent's Avatar
Default C-5 filter
I have a deep TCI pan for my 60. Would it help me if I went with the Corvette filter with the extension on the bottom at the pick up? It just seems it would use more of the fluid.
Thanks.
Mark
Old Jun 8, 2024 | 06:35 PM
FranksCustomTrans's Avatar
LS1Tech Sponsor
Yes but make sure the snout unless provision in pan does not bottom and block itself. If so then cut 4 v notches in the snout about 1/2 inch wide and 1/2 inch deep .
Optionally you can also just a get a filter extension https://www.summitracing.com/parts/s...RoCXloQAvD_BwE
Note most aftermarket deep pans actually come with this included,
Also note the filter sitting on bottom of pan is what helps hold it in and regardless the filter either needs to rest on pan bottom or some other means of support utilized, it can and will fall out.
__________________
