4l60e shift problems
Old Jul 16, 2024 | 01:00 AM
danielsc101970's Avatar
Default 4l60e shift problems
So I recently bought a 5.3 ls enguine with a 4l60e and put it on my 1970 c10 but I can’t get it to run right it starts off in 3rd gear I have to manually shift it to first and shift it to drive I feel it shift to second and third and then it shift down to second or if I put it in overdrive I have to floor it for it to go into third and forth but when i floor it takes off here is a short video
Old Jul 16, 2024 | 08:33 AM
bbond105's Avatar
It sounds as if you don't have it wired correctly. You can check out this website form wiring info. LT1 Swap
If you have a scanner that can read transmission data, that will go a longs way in helping to find out what is going on.
Old Jul 16, 2024 | 09:07 PM
FranksCustomTrans's Avatar
LS1Tech Sponsor
I dont see a short video ?
__________________
