4l80 pump to case bolt threads gave up on me
Are they real Helicoils or some off brand? Are they long enough for the proper thread length? A few of the fixes I can think of, one to try something like a semi solid thread locker, and then making sure the last or upper helicoil wire is below the surface enough to make a stake in the
hole to prevent it from coming out. I'd be very careful with the thread lock, and let it set for a very long time maybe 48 hours or more, and then use solvent or ? to rinse the holes real good. And maybe even make a home made thread chaser from a bolt with no burr left on it, to clean any excess.
Most important the holes and the coil need to have no oil on them when using thread lock.
https://next.henkel-adhesives.com/us...000153639.html
This is just an idea, I've done many helicoils and not had problems with them.
Another better option but only if room a thread insert which is basically a bolt with a threaded hole in the middle. You can buy or I have actually made these from a bolt. But it is tedious. Also you might consider while some might say WRONG WAY just going up a bolt size and threading the case to that on that one bolt. Though you may or may not have to enlarge the hole in pump to accommodate (This is structurally probably the best path) though some would frown on it .
Frank how do you find the time to do everything you do?
Honestly , Im a single old guy with cats and no life beyond doing transmissions lol
On many aircraft type parts it is standard practice to install helicoils in every threaded hole in the part. They will wear much better than cast aluminum will, and even take over torques that cast aluminum will not too well. Its just a me thing.
I do not want to step on the toes of the top guys here that have a bunch of these transmissions under their belts, they know best and likely had certain problems and such.
and yes like on my aluminum heads on my IMPALA I noted they had heli coils in all the rocker stud holes and thought odd , But learned it was normal and in all the LT1 aluminum heads sock.
I only actually noted it because my studs backed out even after permanent Loctite and proper torque , I found that the little tabs at bottom were still there and messing with the torque of the stud , I was afraid to remove them as some of the holes with air applied were through and no idea where they went, So I CUT 2 THREADS off each of the studs so they would not hit that tab anymore. reinstalled again this would be second time , red locktite and torque and no issues since.
Just a useless tidbit lol
Yup Im an old fart lol
https://www.amazon.com/Tooluxe-03703...s%2C130&sr=8-2
