First 4l60e rubuild
Old Dec 10, 2024 | 07:42 AM
LS_S10.2240's Avatar
Default First 4l60e rubuild
Ok so back story i have a 2003 s10 and i just acquired a running lq9 with a 4l60e from a 06 escalade. The trans is 4wd but i have already got a output shaft and tail piece to convert it to 2wd. I also have The beast sunshell for it. The motor isnt going to be anything crazy 450 to 500 hp. Just wondering if there is a kit with everything in it if not does someone have a list of everything i should get. Thanks in advance for any help
Old Dec 10, 2024 | 09:52 AM
2BFAST's Avatar
Doing a search on here will yield you with plenty of results
Old Dec 10, 2024 | 10:33 AM
bbond105's Avatar
Check this thread out and do a search, there is a lot off info in here.
Rebuild kit for 4l65e - LS1TECH - Camaro and Firebird Forum Discussion
Old Dec 11, 2024 | 11:35 AM
Thanks for the info im going to attempt this rebuild myself i am very capable been working on cars all my life but i have never opened up a transmission. But i here if i take my time make sure my workspace is clean and organized there is a certain manual i was told i should grab. I here its real important to make sure any parts that go together fit properly and thats where having experience comes in handy. But it can be done so im going to try just need to get all my parts together
Old Dec 11, 2024 | 12:12 PM
bbond105's Avatar
As you disassemble the trans, lay the parts out on a table in the order that they came out and don't get them out of place when cleaning.
Old Dec 11, 2024 | 07:40 PM
Tranzman's Avatar
I have a book that I have to send via email or create a way to share the file. If you PM me your email I'll send it.
or try this link.
https://www.academia.edu/44487096/GM...ford_McCormick
