TH400 question: slow movement when cold?
Old Dec 18, 2024 | 09:24 AM
fst100's Avatar
Question TH400 question: slow movement when cold?
i recently swapped from 4L60E to a TH400 with RMVB and transbrake. i noticed on a cold start and ambient temps lower than 40*F that the car barely moves on its own at idle in gear. even shifting between gears theres virutally no feeling of engagement. i didnt want to apply too much throttle if it'd cause burning clutches and all. is this typically normal with the TH400?
Old Dec 18, 2024 | 05:32 PM
91 Z28's Avatar
How much fluid is in the trans?? Kind of sounds like the T brake isn't fully releasing. I probs wouldn't drive it at all until I got to the bottom of it
Old Dec 19, 2024 | 06:15 PM
truckdoug's Avatar
probably ought to put a 0-300 pressure gauge on the line pressure port in the case and see whats really going on
