Hard 1-2 shift on LS swap, Need help
I think that i have a problem but im not entirely sure. It could be 100% tune, but i have been trying to fix small things that have been effecting the drivability so i haven't had time to get back with my tuner.
As it stands right now I am on the 3rd transmission. The 1st blew because i was not 100% sure what was going on when i put it together the first time. No tune at all. The 2nd time the torque converter let go and the transmission followed.
Which Transmission
4L60E (about 2,500-3,000) miles since fresh rebuild.
-Which powertrain management
Stock PCM, self trimmed wiring harness
trailblazer intake 92mm throttle body, drive by cable(Not computer controlled butterfly)
-Have you ever checked line pressures?
No, and im not entirely sure how to. But it has good pressure, maybe to much.
As far as i can remember it has always hit hard into 2nd. Under normal acceleration it kinda bumps into second not to bad. But off the line, full throttle it slams into second and breaks the rear tires loose.
Iv blown a transmission line several times, so it has fresh and clean fluid in it. Iv been checking it weekly and the level is perfect. I put a new filter and gasket on the transmission in September.
Anything is appreciated. Thank you!
You need to share:
-Which Transmission
-Which powertrain management (Stock ECU, Holley, Carburetor and a standalone trans controller, etc)
-If the trans has been built...what has been done to it. Namely info on the accumulator and the shift orifice sizing
