4l60e proper rebuild for $1100
Old Feb 23, 2026 | 09:19 AM
2BFAST's Avatar
Originally Posted by Kfxguy
I scuff up the shaft and inside the drum with 400 grit and then use shaft retainer to hold it in.
I had one come to me, the guy told me it was fixed several times in less than a year and 3-4 kept burning. The “builder” had added every shift kit and valve and “fix” to it to make it have more pressure and shift harder in an effort to fix the 3-4 from burning. Cause? Leaking input shaft. I checked it, leaked badly. It’s been doing fine for quite some time now.
I was waiting for you to say he cranked on the EPC screw lol
Old Feb 23, 2026 | 09:28 AM
Kfxguy's Avatar
he probably did. I put another one in there.
Old Feb 23, 2026 | 09:41 AM
2BFAST's Avatar
Its good practice for sure because you cant tell if someone has been monkeying with it. Especially for $20 Rostra
Old Feb 23, 2026 | 10:38 AM
FranksCustomTrans's Avatar
LS1Tech Sponsor
I ran into this a while back with a local stock rebuild cheapie favor. Got done . customer installs and bam bam its shifted hard. He did a presure test idle 135 lol give just a little throttl 200 plus , Gave him a new EPC and all fixed. . You never know, I replace them in most builds but this was a favor for someone "in need" "disabled fixed income" But yes with those you never know, I did make a tester for them but rarely use it as i just replace them as a matter of doing it . As with many things I have just started replacing and fixing rather than test as i found MOST stuff you test Is indeed a problem and just fixing the issue leaks or whatever on all is less time consuming and costly than test then fix .
__________________
Old Feb 23, 2026 | 04:02 PM
2BFAST's Avatar
Speaking of the adjusting screw on the EPC solenoid. What is the reason its there? I mean, obviously its adjustable but in what case would you utilize this?
Old Feb 23, 2026 | 04:44 PM
LS1Tech Sponsor
Its used in calibration, of course new is calibrated but it can also be used to make small ajustements . Like some buiders are dead set on no more than 220 psi max well lets say on a dyno you get 230 , you could ajjust down a little. Or with a base calibration as a model I could get out my homelade tester and calibrate one that was messed with to operate a certain rang in a given currect range. But mostly some turn them up just to get a litle firmer shift or to hide a slippy shift
__________________
