Accidently ordered 5/16" checkballs for 4l60e
Old Feb 20, 2025 | 02:41 PM
Guy with a Chevy's Avatar
Default Accidently ordered 5/16" checkballs for 4l60e
Will they work or should I order up the correct 1/4"?
Old Feb 20, 2025 | 03:08 PM
FranksCustomTrans's Avatar
LS1Tech Sponsor
I mean they probably would work , I never done it, in early days when getting plates and such were hard i occasionally would use one when a hole was worn to large never had issue , But unless you are in a hurry i would get right ones, also note most kits come with new steel ones
__________________
Old Feb 20, 2025 | 06:24 PM
I read your response as soon as you replied and was hoping somebody else would chime in saying they've done it with no problems. It is a customer's transmission so I ordered the correct ones from Summit they will be here the fastest thankfully before the Torrington bearings arrive so no biggie I will eat the shipping and just mention it to the customer when he picks it up for a laugh. Thank you for your fast response. Do you ever deburr transgo plates specifically the #8 3-4 accumulator check ball hole? It is on the rough non beveled side of the plate? Just has me thinking it could be bad for the ball. Never thought of it before surprisingly.
Old Feb 20, 2025 | 06:40 PM
LS1Tech Sponsor
I dont generally use the TG plates but yes when i have i use a hammer on a steel surfce and peen each hole with a ball.
__________________
Old Feb 20, 2025 | 06:44 PM
That is the perfect suggestion thankyou!!!
