CVB oversize AFL valve install
The first one, 2000 v6, I put back together with the original valve.
On this one, 2005 5.3, I measured the first land and it is only .0002 bigger than the one that was in it.
Do these Central Valve Bodies valves slip in or do they need some "sizing" like TG instructions talk about? -Hard side loading-
Or if you want to scrub it in put a spring in front of it of some sort and stroke it in and out a bit. . But it will do that on its own. running too.
I bought 5 pack, I'll measure another one.
On a tangent-
When making the PWM TCC on/off with stock valve by flipping only the inboard valve-
The spring makes getting the end plug back in pretty hard.
I vaguely remember the last one I did was hard but not this hard.
Is flipping the inboard valve only the correct way or do you reverse the whole assembly?
On a tangent-
1- And best of course ream it and put the sonnax assembly in it.
2- use the constant pressure valve and spring by sonnax it limits to about 120 psi.
3- Place a stiff little spring between the isolator valve and VB wall one that will compress you can push down through the channel behind the isolator valve, This will fix it well also. The spring can be found in the harbor freight spring kit , I forget the number but it has two short fat springs the same size one weaker, Use the stiffer one compress . push down in with the isolator already forward it will pop into place. Maintains PWM just at an overall higher pressure. (works well)
4- use the fitzall but again TCC at line pressure.
With any of these IMO with the exceptions of the sonnax and the ftzall . It is important to replace the end cap for this valve , Better yet use orring cap. If you look at the fluid diagram you will see why and this is a sizable leak point in the circuit.
