4l80e Pump Rotor Clearance
Old Mar 7, 2025 | 05:24 PM
TedsB4Csled2's Avatar
Default 4l80e Pump Rotor Clearance
I have a clearance of .013" on the inner gear to crescent on the pump body. This is the 2nd new set of pump gears and 2nd pump body I've tried. The other pump to rotor clearances were in spec. Just curious if others would run it and just verify that line pressure is in spec?
