4l80e Nightmare
I refuse to give up and say i didnt know what the problem was. I also have other work and have been giving this less time everyday.
Force motor high and low run directly to pcm.
Are you still getting force motor codes if so start as mentioned earlier replace that main connector if nothing else so you can first hand verify pin by pin it's all correct.
I'm probably going to throw a TPS at this 6.5 since the TPS went completely dead today after calibrating it from .4 volts to .6 at idle. The drive after the check engine light came on and it started hardshifting and would go into 4th and drop back to third. Went to check the tps again and the reading showed 1-60 milli volts no matter what but confirmed why it was showing a code 22 before I even messed with it. Very weird since it was shifting perfectly yesterday
I brought this 93' C3500 6.5 TDI with a 4l80e problem here because the guys on diesel place don't talk transmissions like you guys do here plus they don't have Frank. I found a diagram with the VSS signal going straight to the TCM before Frank confirmed a somewhat obvious speculation of the TPS causing the pressure and shifting issues. Without live data it was a fun process of tracing and probing connections to verify what was and not. Really surprised the damn TPS was working perfectly before it took a dive, even made me grab another multimeter to check my mind right after calibrating it.
I am happy I didn't give up on this truck as I was starting to get the feeling I should. You must have heard my crying in the posts I made lol
Remember orientation of 4l80e valve body check ball end plugs or you will lose reverse!
