4l70 to 4l80 swap
Old Apr 2, 2025 | 02:01 PM
tonyorlo's Avatar
Default 4l70 to 4l80 swap
I have rebuilt a 4l80e to replace the 4l70e in my 07 TBSS awd (second gear is gone). I have got the hard parts figured out, but I am unsure on the wiring. I have found the pinouts for both transmissions, and everything seems to make sense from what I’ve read for Gen 3 60 to 80 swaps. Move 1 wire, pull 2 wires to connect to VSS. BUT, is this technically a Gen 4 because it has a E67 pcm? If so, does that change anything for the wiring? I ask because the adapter harnesses seem to go for $1-200. Is there more to it than flopping some wires, or do I treat it as a 0411 or p59 conversion?
I have read through stickies and searched with no answer. Maybe it hasn't been asked because it’s a stupid question! Thanks for any help!
