4L60 stator support
Old May 4, 2025 | 05:47 PM
rjpower's Avatar
Default 4L60 stator support
Does anyone have a secret way of getting the hateful little torks bolts out. ????????'
I tried heat then lube . Just brakes bits.
Old May 4, 2025 | 08:07 PM
mrvedit's Avatar
Moderator
I recall using a hand/hammer impact driver like this:
Amazon Amazon
Old May 5, 2025 | 10:12 AM
FranksCustomTrans's Avatar
LS1Tech Sponsor
I take a punch and hit each head hard once, This breaks up red loctite likely used during install at some point, Then hit with my 1/4 inch impact and a good bit not safety type with hole in middle they will break every time.
__________________
Old May 5, 2025 | 12:55 PM
rjpower's Avatar
I put some heat on them and they came loose with 1/4 rachet. Locktite releases at 400-450 deg. i heated the bolt not the Alum.
Should have slowed down and used my head. Thanks guys .
