2003 Silverado 4L60E problems after shift kit install.
looking for some help with my transmission. Recently rebuilt a 4L60E for my truck. Reinstalled and everything worked. I figured since everything mechanically was new, I would install a TransGo shift kit, corvette servo, and some pinless accumulator pistons to tighten up the shifts and prevent any line pressure issues from a worn valve body.
after installing the shift kit, I have reverse, 1st gear, 2nd, 3rd, all shifting perfectly if I shift MANUALLY from the column. When the truck is in drive, I have slipping occurring in 1st, 2nd, and 3rd. At highway speeds, I can shift into drive and 4th gear also functions without slipping.
Trying to get some advice on what may be causing this issue after rebuilding the valve body. I’m planning on taking it back apart tomorrow and verifying that I did everything per the instructions and install a new separator plate.
just took everything apart and found an unplugged connector. (It was long day yesterday)
put everything back together to find the same issue. I saw some posts about the pinless pistons and incompatibility with the transgo shift kit, so I might start by throwing the old pinned pistons back in and see if there is any change.
Contrary to belief they is not inherent problem with using the pinless with the TG kit as long as you stay with the OE spring and layout for the accum.
Like I said CHECK THAT FIRST !
In my case I do not use the TG kit and generally with pinless or stock style metal accums use the stock springs and layout. Depending on application for feed sizes . If HD build the .083 VB accum gets stiffer spring, Moderate performance larger .092 feed with VB accum spring stock. More aggressive performance back to .083 and stock with added VB ACCUM spring (pretty stiff set up) , With very high stall and big power duals springs in VB ACCUM and .092 feed. Accum feed (to back of servo I leave stock.These all when I use wide band and corvette servo Stage 2 and HD build.
Now with the stage 3 and max which use the superior pancake servo. I use stock VB accum spring- .083 second feed and .092 3rd acum feed stage 3 and with the MAX . 093 feed with dual spring VB accum and .092 3rd accum feed.
Needless to say the stage MAX is pretty aggressive shifting . But people do not get those for comfort. and they are used for most extreme duty.
I have never been a fan of overly aggressive shifts In any regular day by day use type unit as I feel it places more than necessary strain on hard parts . In particular the input drum (To me still the weakest mechanical link in the 60E series trans) My goal is alwayS in particular for second is a notable firm little bump at part throttle becoming more aggressive with throttle but never slamming tire squawking even at WOT.
I also may adapt feeds to various situations. Bigger stalls may get bigger feeds, Lower rations like 4.11 4.56 may get smaller holes while high gears like 3.08 in my own car get .092 .
Never cared for modding the 1-2 accum as I find that when this is done I get less than consistent feel at varying throttle levels.
Just my thoughts.
