4L60E switch on shifter
Old May 16, 2025 | 10:17 PM
Scottvsmith's Avatar
Default 4L60E switch on shifter
** Update** as it turns out, it must be a NSS because it won’t start with the sensor unplugged. If anyone has a schematic for this sensor, please post it. Thank you!!!
I have a 4L60E trans with an unknown to me switch on the shifter (1999 Trans Am Console Shifter). I thought it was a neutral safety switch, but I have been corrected as per the wiring of my switch. I’d like to replace the shifter with one that will not support this factory switch. Since it is not a NSS, what is it??? Here is a photo of a shifter with the same switch.
Old May 17, 2025 | 08:30 AM
bbond105's Avatar
This should get you where you want to go.
Old May 17, 2025 | 08:43 AM
Steves1911's Avatar
Green and purple are the neutral safety switch. Just went through this after installing a b&m shifter. You can connect them to bypass the nss or connect them to a microswitch on a aftermarket shifter or connect them them to a switch if you'd like.
Old May 17, 2025 | 09:30 AM
I’m gonna have to crawl around and locate the NSS and it’s wires as this is my connector. And I’ll read the schematic and figure out what exactly the other 4 wires are. Thank you guys for your assistance!!!
Old May 20, 2025 | 06:38 PM
bbond105,
Thank you sir!!! The schematics got me what I needed.
Old May 22, 2025 | 09:02 AM
bbond105's Avatar
Originally Posted by Scottvsmith
bbond105,
You're welcome, I'm glad they helped.
