Please help. Cannot figure out po742 code
FIXES are several. REPLACE CRV with sonnax requires boring tool. Some replace isolator valve with spring from sonnax that sets a constant pressure around 110 PSI as I remember. Others use the fitzall valve which eliminates PWM all together and puts TCC equal to line which is probably ok in stock configuration , But would not suggest if running WOT lockup as may damage converter backing plate and clutch. Some put the CRV in backwards. I have not done this but many say they do , This would also put converter equal to line. Some block the valve same result, Other like myself add a helper spring which keeps PWM at a slightly higher pressure.Some use this from transgo https://res.cloudinary.com/transgo/w.../4L6-ISO-3.pdf , I have seems to work well. Unfortunately all require removal of valve body unless you get lucky and someone put the clip in from the other side. I do this sometimes as i sometimes have a shorter clip that works well as a just in case thing. But the normal clip upside down you have to be careful of the harness there as the filter pushes it hard against the clip.
In all cases I replace the end cap of the valve train as it is a major leak point in the oil circuit with an o'ringed type
Any of these of these ways will work just depends on how far you want to get into it as long as converter clutch has not yet been damaged.
BAD TCC SOLENOID
STUCK OR MISSASSEMBLED TCC VALVE IN VB
BAD TORQUE CONVERTER OR WRONG BOLTS USED.
Not the CRV , However never heard if that causing HIGH line , More likely the feel of a shift with converter applied which will feel quite harsh.
Check TCC solenoid and valve above it first.
Make sure you did not use non OEM TC bolts that are too long.
I know this will be a pain in the behind, but you could just leave the TCC solenoid out and go on a test drive. If converter doesn't lug the engine, then you know the problem is in the solenoid or its controls.
