4l60e 1-2 shift issue
Old Jul 9, 2025 | 03:22 PM
Bgchris1's Avatar
Default 4l60e 1-2 shift issue
Afternoon
Have a 1988 d150 with a 6L( mild build. 222/224 cam 3200 stall longtube true duel. Holley terminator max x) with a 4l60e controlled by a holley terminator max x and a circle d 3200 stall and transgo hd2 shift kit.
Issue i am having is from a dead stop or below 20 km/h if I go full throttle it will pull until about 5500-6000 rpm, then act like it goes into neutral. Will only go back into gear if I stop throw it in park then back into drive. Will.shift perfectly after wards. Above 20km/h full throttle will.shift no issue.
Any insight to what to look for or try would be much appreciated.
Old Jul 10, 2025 | 12:04 PM
bbond105's Avatar
I don't know anything about the holley terminator max but if this was a factory control unit I would say that your problem is in the tune.
