Jegs 60400 converter
JEGS Torque Converter For GM TH-350 And TH-400 Transmissions | 2300-2700 RPM Stall Speed | 10.75” Flexplate Bolt Pattern | 500 Horsepower Maximum Applications
The add says
- IDEAL for small block applications up to 500 horsepower without nitrous or super/turbochargers
I'm pushing 10-14 pounds of boost to a bone stock long block 5.3 LS so should be making around 500 HP in a 3500 LBS car. I figure 500 HP is 500 HP - I just won't tell the converter I got a turbo and it should be fine right?
I know you get what you pay for but i got zero $$$ into the TH350 aside from the converter and I know the TH350 won't last long so it makes NO sense to pay up for a good converter (this is just to get improve the launch up until the trans blows and I get a 4L80E to replace it)
