Tranz oil types and converter trans note
I wont mention the company but DO NOT DO THIS. The only way it would be acceptable would be if PWM pulsed width modulation was either mechanically or in tune eliminated .
Doing so without these can/ will result in serious converter chatter during lockup clutch apply and release and even under some driving conditions which trust me is a horrid feeling or vibration like feel in the car or truck .
Not to mention TYPE F has 0 advantages over DEXRON 6.
TYPE F IS FOR ANTIQUE FORDS with C6-C4- PRE- LOCKUP CONVERTER ERA TRANS .
Na I dont play the name and shame game, They are not a sponsor here I will say that. Just was blown away.
Been here done that with someone using TYPE F in a PWM trans and it shuddered like hell during lockup engage and at low speed lockup when PCM allows it to slip ,
Solution was TRANS FLUSH and even then took DEX 6 AND 4 BOTTLES of LUBEGARD SHUDDER FIX Friction modifier to get it right . Was ok after that however.
Now way back in the day people did put TYPE F in th350s and 400s . It had a higher heat range and would give a little firmer shifts . But lockup units and such or like the 700r4 and 4l60e with overlaps on 2-3and 3-2 no way . Todays fluid's are so so much better in every possible way .
I thought F was similar to what B&M fluid was, since it supposedly offered less friction reducing additives than Dexron. I'd only be adding any special different fluids if the parts were all new clean etc. I'd never be mixing them.
But with the coming of lockup converters this was problematic, In the early days it would just result in an abrupt grunt on apply. Annoying but livable. But then the 700r4 and the 2004r and overlapping 2-3 3-2 didn't work out well . Then the PWM converter clutch instead off on off and chatter chatter rumble.
Not that I think it will actually cause harm as such at least not in the shorter term. But it just makes no sense. Newer synthetic oils handle far more heat , last longer, protect seals better, lubricate parts better and have much more stable viscosity. They literally do everything better.
