4l80 tcc drag using a multi disk
Old Oct 12, 2025 | 02:57 AM
K20LEPIPE's Avatar
Default 4l80 tcc drag using a multi disk
Hello everyone I went ahead and replaced my stock stall on my 4l80 /ls3 swapped truck (factory stall was a turd) but did serve me well for over a year , I installed a 10inch 3600-3800 multi disk stall and after a few miles the next day I got the infamous tcc drag , ( truck would turn off aggressively as soon as I tried putting it In gear ) I see a lot of ppl fix this by installing the Sonnax line to lube PR valve to help feed the tcc release circuit , but my 80e allready has a “superior “PR valve installed when i built it ,which already has feed provision for tcc (small notch on it ) any pointers on where to look to solve this ?
setup is ls3 /cammed obs truck /4l80 trans : dual fed ,superior shift kit (includes said PR valve with notch on the land )
Old Oct 14, 2025 | 07:46 AM
FranksCustomTrans's Avatar
LS1Tech Sponsor
Well In car it hard but a .083 feed through pump wall there can help. also raisng AFL presure in tune can help , Likly you have a worn AFL valve . this can cause 2nd gear starts and dragging TCC at idle . Also if using the SONAX tcc regulator valve with tef ring using the stiffer of the two springs that came with it can hellp or get it and install it with the stiffer spring.
__________________
Old Oct 14, 2025 | 10:07 AM
K20LEPIPE's Avatar
Hmm I see , well regarding the afl valve , I have never had issues with 2nd gear starts , my only problem is tcc drag . Only change was removing the stock stall in replacement of this triple disk . One thing however that Cought my eye was that with this converter I had tight clearance , I believe I was bearly able to squeeze in the feeler guages to about .125 , converter did spin by hand but it was tighter then I normally use it maybe tighter then .125 since I had to jam in the feeler guages
Old Oct 14, 2025 | 11:35 AM
LS1Tech Sponsor
Oh man dont run any more, You need a min of 1/8 inch and really with an 80 i would rather see 3/16 a min, Its likley you are pushing the gear into the pump back, HOPING no damage allready . You need one of these, not nessarily this thick they make them as thin as 1/8 inch
Amazon Amazon
__________________
Old Oct 14, 2025 | 11:53 AM
K20LEPIPE's Avatar
Originally Posted by FranksCustomTrans
Oh man dont run any more, You need a min of 1/8 inch and really with an 80 i would rather see 3/16 a min, Its likley you are pushing the gear into the pump back, HOPING no damage allready . You need one of these, not nessarily this thick they make them as thin as 1/8 inch https://www.amazon.com/Camotokiit-Tr...zcF9hdGY&psc=1
ok this is what I have been trying to get to with out me feeding someone this idea , After hours of reaserching I saw one post where they mentioned thight converter to pump clearance “amplifying “ the tcc dragging . (That is all the info about this I saw , I believe it was circle d member who said this ). He also mentioned this was seen in customers who had less then .100 clearance , I wish they elaborated more on this because I suspect that maybe the converter being that pushed in blocks a lube circuit of some kind ?
Do u know if having that tight converter spacing would block a return flow or any passage ?? (And yes I’m aware of the tight clearance destroying pumps , but since I got the .125 gauge in (thightly ) I rolled with and converter spun freely
Old Oct 14, 2025 | 12:37 PM
LS1Tech Sponsor
trouble is the flex plate well FLEXES , And Alhough I am not a converter guy. Its my understanding the put shaft itself can push in on the TCC and cause drag when clearance to tight .
__________________
Old Oct 14, 2025 | 12:39 PM
LS1Tech Sponsor
Here is what I would do, Your clerance is really to tights, First thing pull pan if you find cast iron dust well you know a clean up and pump is due . of not then i would add the spacer probably a 1/8 one .
__________________
Old Oct 14, 2025 | 04:14 PM
K20LEPIPE's Avatar
ok thanks for confirming so I can be more willing to do the spacer , I got some spacers that are gonna give me 1/16 more of clearance so that should put me really close to 3/16 . The pump clearance should be fine I’ll check that after I just shim in the spacers with out moving much out the way I think I can slide them in with only loosing bolts
Old Oct 14, 2025 | 04:27 PM
K20LEPIPE's Avatar
Old Nov 4, 2025 | 10:07 PM
K20LEPIPE's Avatar
Update got a 1/4 spacer installed between the engine and trans and was able to set proper converter to flex plate clearance and all is good. Be sure to have enough converter to flex plate gap guys !
Old Nov 5, 2025 | 10:10 AM
rpturbo's Avatar
Good to hear! Thanks for posting a resolution.
Old Nov 5, 2025 | 01:30 PM
LS1Tech Sponsor
Excellent I have noted this on a few 80e units when they come into be built the have excessive wear at back of pump center gear and on more than a few I have after having them check this found the clearance too close, Its seems to only happen with after market converters but has happned with a couple remans. Not to long ago a guy had to put in a 1/16th snim just to get over 1/8 inch after I noted wear in pump and had him check on reassembly.
Of course otehr things can happen to had another guy after checking his crank thrust motion we determined his engine was trying to us his converter as a thrust bearing , It was worn slap out .
__________________
Old Nov 5, 2025 | 02:16 PM
K20LEPIPE's Avatar
Yes I got lucky no damage to pump body , I was really tight but not enough to make contact with anything , issue seems to be when the converter is pushed in that much u are blocking some flow therefore creating high line pressure and making the tcc stay engaged
Old Nov 10, 2025 | 07:21 PM
5.7stroker's Avatar
4L80E
FTI triple disk
Pump wear plate
0.14 converter clearance, no shims used, perfect right out the box
.093 line to lube drilled
stock PR valve
no modifications to any of the other valves in the pump
jake’s D3 transbrake
EA adjustable pressure regulator (version 1) with 1 shim
185-190 pressure at wot
Front cooler port pressure when locked is 95
Front cooler port pressure when unlocked it 50
950 rpm idle
No converter drag
I’m aware of the modified PR valves and additional pump mods but I’m going to run it like this for awhile and see how it does.
Old Nov 12, 2025 | 04:06 PM
LS1Tech Sponsor
Originally Posted by 5.7stroker
4L80E
FTI triple disk
Pump wear plate
stock PR valve
950 rpm idle
No converter drag
Interesting , In The OP case he did not have enough converter to flex plate clearance, I have seen this a few times causing dragging lockup. I can only assume the shaft is pushing in on the lockup disc , .
__________________
Old Nov 12, 2025 | 04:20 PM
5.7stroker's Avatar
Yeah I think I got lucky with the converter being correct right out of the box with no shimming needed.
Old Nov 12, 2025 | 05:03 PM
LS1Tech Sponsor
4L80E CONVERTERS ARE WEIRD AND really wish people would not say 1/8 to 3/16 on these as it seem the min really should be 3/16 IMO pads to flex plate, The pump gears are a totally different animal between the two . Probably seen t half dozen times over the years, Had one guy call me he had allready all the hydralic fixes and no fix. He did some measuring and found he had exatly 1/8 , I mentoned tthis could be a problem and being a mchinish he went a different route put the whole conveter in I think h said router or something and cut down all the pads 1/16 . Said he didnt care for the spascer iead. And he said he had a multi million dollar machine shop in his back yard and could do anthing. But sure enough that fixed it lol.
__________________
Old Nov 13, 2025 | 12:00 PM
FTICONVERTERS's Avatar
LS1Tech Sponsor
1/8 to 3/16 converter pull out is perfectly fine... if the flexplate is flexing more than 1/8 something else is wrong. Can this clearance effect fluid flow out of the converter, effecting TCC drag/float? Sure but if you have a min of 1/8 it should be fine assuming all else is done correctly. 1/4 is absolute MAX pullout. any more and you risk the converter driving the pump gear into the housing or not getting full gear engagement and breaking the gear/hub.
-Dalton
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
