4L80 Park Neutral Position Switch - which to wire to PCM #34?
Which of these pins on the 4L60/4L80 park neutral position switch should I send to the PCM blue connector #34 to tell the PCM the car is in park / neutral? Would this change the idle in park / neutral, or is this to prevent the car from starting outside of park / neutral?
