Th350 Ds ???
Old Aug 9, 2004 | 05:06 PM
Raped-Ape's Avatar
Default Th350 Ds ???
will the stock 4l60e steel ds work on a th350??? i have searched and found mixed responces, im about to do this swap .
tia
-jonny
Old Aug 9, 2004 | 05:28 PM
Colonel's Avatar
It should if the TH350 has a 9" (instead of 6" or 12") tailshaft housing.
4L60-E = 31 5/32"
TH350 w/6" TS housing = 30 11/16"
That's less than a half inch difference.
Old Aug 9, 2004 | 11:17 PM
Raped-Ape's Avatar
thanks colonel
where can i find a 9' tailhousing at, cause i think its the 6. or would i be better off getting another driveshaft??
tia
-jonny
Old Aug 10, 2004 | 12:48 PM
Colonel's Avatar
I don't know where you could get one. Guess you could check with some tranny shops and/or salvage yards. The output shaft would also have to be changed. I think I'd just get another driveshaft built.
Old Aug 10, 2004 | 12:57 PM
Spl170s's Avatar
Drive shaft would be easier to deal with in the long run..........
Old Aug 11, 2004 | 12:22 AM
Raped-Ape's Avatar
thanks guys. i appreciate the help
-jonny
