Shift Pressure?
Old Aug 18, 2004 | 08:25 PM
Gonzo1's Avatar
Default Shift Pressure?
Got a 2000 SS and installed predator today. Raised line pressure to +25%. That is the max with the predator. Just wanting to know if that is safe for a stock tranny. Love the way it shifts and grabs a second anytime you want! If that is to much someone let me know!
Old Aug 18, 2004 | 09:35 PM
GETSOMZ28's Avatar
should be safe. make sure you also change the shift duration to make them quicker.
Old Aug 18, 2004 | 11:06 PM
Gonzo1's Avatar
Is shift duration the same as shift adaptation? Thats what it reads on my predator. Also what should I set shift adaptation to now that I set the shift pressure to +25%? And if theres anything else I need to change please let me know what to change and how much!
Old Aug 19, 2004 | 05:58 AM
ArmyVette's Avatar
Red, check out the sticky thread at the top of this forum. You'll find plenty of discussion on this subject.
Old Aug 19, 2004 | 05:53 PM
GETSOMZ28's Avatar
redNATA, yes shift adaptation is the same as shift duration (quickness of shift). It is pretty same to bump those up to +25% also.
