TH-350 Question
Old Aug 24, 2004 | 08:55 PM
Ru2slo_99's Avatar
Default TH-350 Question
I am about to put a th-350 in my daily driver. My friend has one with a shift kit and 3500 B&M converter, but it has the kickdown cable in it. If I buy this trans, how do I remove the kickdown cable?
Old Aug 25, 2004 | 02:23 AM
Automatics's Avatar
Restricted User
Don't hook it up if you do not want it to kickdown. Now you will have to bring the lever back for it to downshift.
Old Aug 25, 2004 | 04:47 AM
GTS346's Avatar
Just build the TH350 with full manual valve, so its manual up and downshifting.
No need for kickdown cables, no PCM problems etc.
Old Jan 5, 2005 | 10:35 PM
Hambone 7's Avatar
what do you do if you have a kickdown cabe and you have no need for it? remove it and plug the hole on the transmission?
Old Jan 6, 2005 | 10:24 AM
Rock-On's Avatar
Default hey
yep...hope this helps Dave
