4L80 question...
Thanks!
-rob-
The weakness of the overdrive is that you cannot get exotic clutches for it. For this reason it cannot handle a WOT 3-4 shift under more than 600 ft/lbs. torque, even at maximum line pressure. The hard parts can handle it with no problem, it's the clutches where the weakness is. For the Forward, Intermediate, and Direct clutches (1,2,3) there are all kinds of performance materials available. Those clutches can hold just as much as a TH400 since they are the very same.
Besides, you can actually have your stock PCM shift the 4L80-E instead of having to do it yourself. If that sounds boring a TCI transmission controller can shift it automatically or switch to manual mode on the fly for use with shift paddles.
As far as Gear Vendors OD vs. 4L80-E OD there's no comparisson - the Gear Vendors is a magnitude more capable of shifting the power.
You can have both, it would just be a lot tighter in an F-Body than what I've got!
you will see this 4800lb truck run 9's(with a FLP built 4l80e). give me another year
Ditto that!!!
might not be this season, but by next year, 9's with the AC still in the car and overdrive in the trans. I am not quite as heavy as Parish(my car weighs 3575) but like him, if i can drive the car on the street and enjoy it, then there is no since in having it............... The 4L80-E provides the advantage of being completely programmable. I'm talking about exactly when you want shifts at part throttle taking place based on throttle position and speed, and also the line pressure based on TPS. These things can be set up to provide silky-smooth stock-like shift characteristics at low throttle even with a moderately calibrated shift kit and exotic clutches installed. At the same time they can pin you to the seat with WOT shifts so fast the front end gets light. In my opinion the best way to use this trans is to let the PCM or trans controller run it exactly according to the way you want it. The 4L80-E responds so well to "tuning" I think it would be a waste to convert any of the electrical functions to manual. Also, TH400's don't have locking converters unless you buy into expensive aftermarket technology to do so. With the 80 you can program which gears to lock it up in, what speed, WOT yes or no, and how hard. Beat that. The 4L80/85-E is more awesome than mere words can really do it justice. I seriously love mine, and I built it myself.
I'm running a stock 13" converter than only stalls at a dismal 1900RPM.
Here's a link to a thread with a recent video.
https://ls1tech.com/forums/multimedia-exchange/213007-video-taken-inside-0-80-weekend.html
Hopefully that gives you an idea of how precisely they can be managed. I'd like to hear comments on that thread!
