LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Automatic Transmission (https://ls1tech.com/forums/automatic-transmission-13/)
-   -   tranny won't work (https://ls1tech.com/forums/automatic-transmission/214943-tranny-wont-work.html)
Big_Mac Sep 11, 2004 05:07 PM
tranny won't work
I installed a th350 into my jeep, bolted to a chevy350 on one end and a dana 300 transfer case on the other, after filling transmission up with fluid I started the jeep, tried to shift into drive and got nothing? shut engine off tried rolling jeep while trans was in park and jeep rolls with no resistance. driveshaft turns but flywheel doesn't? I'm no mechanic so any help will be appreciated.
White98Z Sep 12, 2004 01:19 AM
Is the shift linkage hooked up are you even getting it out of N on the tranny it self. Just a thought
Big_Mac Sep 12, 2004 01:24 AM
Yes linkage is all hooked up, installed new b&m shifter.
White98Z Sep 12, 2004 01:29 AM
Does it feel like anything is happening when you shift rpm change. Or any noise at all.
Big_Mac Sep 12, 2004 08:07 AM
no noise, no r.p.m change.
rozzyroz Sep 12, 2004 08:30 AM
ill retract my statment until you have a bit more info :) i dont want to look like a tool :thumb:
TeamTripp Sep 12, 2004 09:25 AM
I'm not familiar with the Dana 300, is it selectable 4WD? Does it have a nuetral position? I actually had a Suburban towed in for a "transmission concern" because it did exactly what you describe and we noticed the transfer case was in nuetral.
Big_Mac Sep 12, 2004 10:00 AM
yes it is a selectable 4wd, does't work in 2 or 4wd.
EDS01SS Sep 12, 2004 11:20 AM
Are you sure your transfer case is good?It sounds like its not engaginging properly.
Big_Mac Sep 12, 2004 11:37 AM
Transfer case was fine when I started the project.
john kilgore Sep 12, 2004 11:52 AM
4x4
are you sure the tranny output splines reach the t case splines?
Big_Mac Sep 13, 2004 07:29 PM
Thanx for the help fellas I feel stupid but the new engine and trans combo pushed my trans case towards rear of truck and floor was stopping 4x4 shifter from engaging.Duh!
EDS01SS Sep 15, 2004 04:34 PM
Dont kick yourself in the ass to hard.We have all been there and made mistakes.Glad you found the problem and that we could be some help.
© 2026 MH Sub I, LLC dba Internet Brands
