4L60E / 1-2 Shifting when Hot
1) When shifting from 1st -> 2nd jumps, OR,
2) When selecting Reverse or Drive / OD from Park or Neutral you can feel it engages. Then when accelerates to run it jumps. Is like a second engaging but stronger. In this case the 1 -> 2 shifting is Ok...
The shifting from 2 -> Drive -> OverDrive never have problems.
While reducing speed nothing wear is noted.
It happen too that when selecting 2nd being stopped, it starts in 2nd and not in 1st.
Interesting, Isnīt it ?
One guy with some experience told me that similar problems have been soved replacing the Valve, Pressure Control, GMC Part No. 24220158. Could it be possible ? . Where can I find the possible bulletin / tech notes for the valvebody of those trucks ?...
Thanks in advance...
Maybe you could ask a service advisor or a tech at a dealership.
I have replaced entire valvebodie's because of the bulletin. wish i had specific details on that bulletin.
Pressure control solenoids have caused a lot of garage shift problems and some shifting problems(mostly 1-2). could be electrical or mechanical. i have ****-canned a bunch of PC solenoids in FWD GM transmissions 97-99 for
these symptoms.
Found some
87-71-74 NOV 98 A/T - 1-2 Accumulator Piston/Outer Spring Replacement
01-07-30-012 APR 01 A/T - 4L60 E Revised Valve Body/Spacer/Gaskets
01-07-30-023B MAR 02 A/T - 4L60-E Harsh 1-2 Gear Upshift/MIL/SES/CEL ON
Could the "jump" you are describing also be described as a "clunk?"
GM has notorious problem with slipyoke sticking causing a condition that feels like a transmission or suspension jolt, bump, or clunk.
Also, putting the selector into "2" from a stop will make it take off in second. This is an intentional feature for slippery conditions.
