4L60E-Which Clutch Set?
When tearing down the internals of the tranny, you have the input drum assembly. Now, there is a set of clutches you have to remove before getting into the deep internals of the 3-4 clutches. Which clutch set is that you have to remove to get to the 3-4 area? These are what are toasty.
Thanks!!
The other clutch pack is probably the low/reverse. Use the RayBestos Z-Pak clutch set for the 3-4. While in there replace the band with a Kevlar unit too. High-Performance materials are available.
