TC install help... too far from flywheel?
So, am I still on track here or is something screwed up?
Also, what is the total capacity of the 4L60e? And is it true that I should fill it with like 4 quarts, and then crank and moee through all gears, and add as I need it?
Thanks a lot,
Derek
I just install my SSF 3500 and made the mistake of trying to pull the TC in with the first bolt and couldn't get the all three hole to line up.
Just get them all started and evenly tighten down then tq to 44 ft lbs (what the books has) if you can.
I only got it to 22 ft lbs and it start spinning, good thing I use a lot of lock tight!!!
I've got loctite somewhere here from my cam swap, but really how important is it?
