TCI SSF converter ?
Old Sep 19, 2004 | 10:06 AM
turboo16's Avatar
Question TCI SSF converter ?
which SSF converter will be better on the spray? The 3500 w/ 2.5STR or the 3800 w/ 2.65STR ? any info on either will be helpful
Thanks
Old Sep 19, 2004 | 12:54 PM
boomcase's Avatar
The lower the stall the more rpm pull you will have with the nitrous . The higher stall will help you NA . Either way your gonna need some new tires to hook up..
Old Sep 21, 2004 | 02:32 PM
Kevin Winstead's Avatar
The 3500 will be better suited to a 150+ shot. For a 250+ a 3000 stall would be more appropriate.
Kevin
