View Poll Results: Will I have to tune my car for the ST3500?
Yes, you will need to buy LS1 Edit, no option.
1
25.00%
No, you will be fine with the predator tuner.
3
75.00%
Voters: 4. You may not vote on this poll
Will I need to tune after my ST3500 Install?
Old Sep 22, 2004 | 12:23 PM
t1blackout's Avatar
Default Will I need to tune after my ST3500 Install?
I have purchased:
ST3500
B&M Tranny Cooler
Trans-Go Shift Kit
Hooker Longtube headers
ORY
02 Sims, EGR Block off.
Will my predator tuner be enough for these mods? I can change shift points, shift firmness, shift time, Spark Timing/Fuel, etc.
My question is, will I have to tune my car (With something other than the predator) in order to make my car work ok with the ST3500?
I am hoping that I wont need to buy ls1edit right now because i cant afford it. Will the converter just go in and work (with exception of shiftpoints being altered).
Thanks!!!
Old Sep 22, 2004 | 08:33 PM
Ragtop 99's Avatar
I did not require any tuning at all with ST 3500.
Old Sep 23, 2004 | 01:00 PM
rufretic's Avatar
I can't say for sure but with my vig 3800 a basic tune made a huge improvement.
Old Sep 23, 2004 | 02:58 PM
HAHA I 1's Avatar
I had virtually the same mods as you. I did not get a re-tune because LS1Edit was not available at the time. I used a HPP3 to change the shift points and raise the rev limiter. I ran it with a SY3500 and no HPP3, but was hitting the rev limiter. The shift point changes and rev limit change made a huge difference. I ran 12.32 at 111mph with FLPs, cutout, lid, SY3500 and the HPP3 tuning. My car was also running very rich.
Old Sep 24, 2004 | 12:55 AM
2000TransAm24's Avatar
I don't know about the ST3500 but my SSF3500 had unlocking issues due to misfires that a Predator won't be able to cure. So if you care about highway driving then you'll need a tune. But if you don't have any unlocking issues then you'll be fine and everything I just said is useless. Also, why would you want LS1edit, Hptuners Rocks.
Old Sep 24, 2004 | 01:19 AM
2MuchRiceMakesMeSick's Avatar
It was not needed after my yank 3600e. You will get better performance if you change your shift points but I would wait until I got some more mods before I go for a tune.
