4l80e questions.........HELP
And it still shows bone dry on the dipstick, and when I am driving it, it will slip out of third back into second. It will even go back and forth if I let off the gas and shift to 3rd, then slip back into second????? any ideas, could this transmission possibly hold this much fluid?? all I have is the factory tranny fluid cooler in the radiator. And if so, then could the low fluid be causing it to slip???? Any help would be greatly appreciated.Thanks,
Remington
Check level with the engine running, in park, warmed up, and on level ground.
Remington
Remington
It seems to be the best upgrade for me too.
Thanks.
Remington
