Big Stall 4000+ Plus guys i have a question
Old Sep 26, 2004 | 05:08 PM
SSPerformance's Avatar
Default Big Stall 4000+ Plus guys i have a question
Got my TCS 4400 Stall converter in and just got one question
It seems at lower speeds that i pull more rpms then i use to with the stock one, IS this rite or is my trans on the way out.
Old Sep 26, 2004 | 05:16 PM
Jorday's Avatar
my 4200 stall converter runs more rpms at slower speeds until the converter locks up, then I run the same rpms as stock.
Old Sep 26, 2004 | 05:18 PM
yea that exactly what i was looking for. It almost feels like it sliping at low rpms rite?
Old Sep 26, 2004 | 05:28 PM
D Rock's Avatar
It should, thats what people mean by the looseness or tightness of a converter.
Old Sep 26, 2004 | 06:30 PM
o ok thanks. i thought i killed my trans
Old Sep 26, 2004 | 07:08 PM
D Rock's Avatar
LOL, enjoy the converter man, I wish I had a bigger one.
Old Sep 26, 2004 | 07:14 PM
i did a TC 4400 stall. all i got done to my car is long tubes a lid , borla. i took my car out today with the e-t streets with 10lbs in each tire launched the car at 2100Rpms a spun them a good 30 feet. the tires where not cold i was drivining on them for a good 10miles first.
Old Sep 26, 2004 | 07:35 PM
F1_SS's Avatar
Same problem here on a PT4000
Old Sep 26, 2004 | 07:45 PM
SmokingWS6's Avatar
What you are experiencing is normal. Its physically impossible to have a stall that turns the same rpm's at part throttle then flash to 4000+ at WOT. Its perfectly normal and you'll get use to it in no time.
Old Sep 26, 2004 | 07:51 PM
any sugestions on where to start with my suspension now
Old Sep 26, 2004 | 08:29 PM
D Rock's Avatar
I would say Torque Arm, Lowercontrol arms, panhard rod, hal shocks.
Old Sep 26, 2004 | 11:17 PM
panhard rod.... i thought thats only for road racing and dosent affect drag racing
Old Sep 27, 2004 | 08:43 PM
D Rock's Avatar
Well it makes sure your rear is centered after lowering the car if your gonna do that, so thats why I did it.
Old Sep 27, 2004 | 09:04 PM
Need2gofaster's Avatar
you did a good thing by going with that big converter....most people regret not going big enough. good luck hooking up off the line!
