B&M deep tranny pan installed...
Old Oct 8, 2004 | 02:33 PM
TNormZ28's Avatar
Default B&M deep tranny pan installed...
My tranny would bounce the limiter several times before shifting. Ofcourse I thought it was slipping at first. Then I was told that a deep tranny pan may fix the problem. Well, I got one on there and the tranny shifts when it should. The force holding the fluid towards the back didn't allow enough pressure to shift the car. Man, I am glad I spend 140 bucks instead of several hundred on a tranny rebuild. Just wanted to throw this out there in case anyone else had the issue recently. I had heard this was a problem with higher horsepower cars but I'm a measly minor bolt on car.
Old Oct 10, 2004 | 02:59 AM
01SSCloneZ28's Avatar
wow, just solved an issue i used to have! what kind of deep pan did you go with? if you got it online, whats the site? i've had several tranny issues in the past....even went through 2 4L60E's....thanks to warranty the trannies only cost me $200 each .......i am a measly bolt on car as well....and i have had issues with cracking the tailshaft extension housing......one time i was going about 130 mph racing another Z28....and the time before that was on the dyno.....have any ideas on how to prevent the ext. housing from cracking? i was told that by installing a spohn torque arm with the driveshaft safety loop, that it would pull the stress off the ext. housing....
Old Oct 10, 2004 | 03:23 AM
2MuchRiceMakesMeSick's Avatar
Good info. im sure some people will be glad that you posted this.
Old Oct 10, 2004 | 02:28 PM
TNormZ28's Avatar
I got the pan from a local shop, Extreme Performance.
Last edited by Ragtop 99; Oct 12, 2004 at 07:05 PM. Reason: Non-sponsor contact & pricing info
Old Oct 10, 2004 | 03:07 PM
Mean Green z28's Avatar
Originally Posted by 01SSCloneZ28
... have any ideas on how to prevent the ext. housing from cracking? i was told that by installing a spohn torque arm with the driveshaft safety loop, that it would pull the stress off the ext. housing....
That is right. The redesigned Spohn Torque arm relocates the front mount to the a cross member (that attatches to the frame in place of the wimpy sheet metal piece that comes installed from the factory) and not the back of the trans, thereby taking the stress off the trans and the trans mount. The droveshaft loop is part of the crossmember.
Old Oct 10, 2004 | 04:50 PM
so your saying that i wasnt bullshitted about the loop and ta??? also.....should i go with a 3500 stall before a transgo shift kit? ive heard that if i wait to do a shift kit, and get the stall first....that i should be good to go.....ive been having some financial issues as of late and have had to pay off my first 2 tickets i got last week
Old Oct 10, 2004 | 06:09 PM
98Raptor's Avatar
Do the converter first.
Old Oct 12, 2004 | 03:28 PM
TNormZ28's Avatar
You can do the shift kit first if you want. It will help slightly. But the verter is the biggest help.
Old Oct 12, 2004 | 03:31 PM
98Raptor's Avatar
SS1421
Do I know you?
Old Oct 12, 2004 | 03:33 PM
TNormZ28's Avatar
Trace at XP
Old Oct 12, 2004 | 04:09 PM
98Raptor's Avatar
Cool
Have we met?
Old Oct 12, 2004 | 04:10 PM
98Raptor's Avatar
True.
The converter will cause your shifts to soften up allot. The shift kit will make them hard and fast.
Old Oct 12, 2004 | 04:47 PM
ULTIMATEORANGESS's Avatar
that pan is a nice part.
Old Oct 12, 2004 | 04:52 PM
98Raptor's Avatar
Very true.
I have the Art Car deep pan on mine and it is very nice.
Old Oct 12, 2004 | 07:06 PM
Ragtop 99's Avatar
TCI also makes an excellent deep pan.
Old Oct 13, 2004 | 01:00 PM
Originally Posted by 98Raptor
True.
wouldnt the hypertech be just as good as a shift kit for the time being? i mean i AM gonna install a shift kit after the convertor...just wanted to know if the hypertech would harden up the shifts
