1350 yoke for 4L60E?
Old Oct 9, 2004 | 07:52 PM
02 Silver Z's Avatar
Question 1350 yoke for 4L60E?
Does anyone make yoke for a 4L60E that will accept a 1350 u-joint? I`m gettiing ready to order a DS for this 12-bolt I have on the way and heard most people talking about a conversion u-joint (1350/1310 I believe) to adapt to a 4L60E, but I`ve never heard about any one making a "beefier" yoke. Are there any companies out there doing this?
Thanks,
Eric
Old Oct 9, 2004 | 08:16 PM
James B.'s Avatar
Are far as I know only 3R yokes are available for the 4L60-E. The easiest thing to do is use the adapter joint on the aft end of the stock driveshaft for the pinion yoke. If it turns out you have to have the driveshaft shortened you will be having to buy another end yoke anyway - might as well make that one a 1350.
Old Oct 10, 2004 | 07:54 AM
2MuchRiceMakesMeSick's Avatar
its a precision u joint #447 that you need to adapt a 1350 to 1310
Old Oct 10, 2004 | 07:17 PM
Right. But does anyone make a yoke for a 4L60E that will accept a 1350 u-joint so you don`t have to use a conversion joint?
