4l80e install in a 67chevy ll
Guys I need some help here I am getting a 4l80e trans for my car. I would like some of you that have the trans to help me with parts that are needed and where.
I DID THE SEARCH AND READ BACK 1 YEAR!
1) who makes a 3000 rpm converter with lockup for it? staying under 1000.00
2) I have a 700r4 now, will I need a new spline shaft on the driveshaft?
3) I will be using a speedpro controller.
4) On the 98 model trans which line is the feed and which is the return?
5) Will a 98 model trans bolt uo to a early model block? pre 87.
TCI has torque converters for the 4L80-E. They are in-stock at Summit usually.
The tailshaft is different and much larger. You'll need a 1350 yoke. The 4L80-E tailshaft is drilled for an optional fixed yoke - if you don't mind using a splined driveshaft.
The SpeedPro / TCI Transmission Controller is AWESOME. I have one and completely love it. You will need to retrofit a throttle position sensor to your carb. (if carb'd) It also need tach signal. The controller can be programmed to shift whenever you want as hard or soft as you like, it can lock up the torque converter at whatever speed you want and as hard as you would like it to. The controller supports paddle or slap-stick input for manu-matic fingertip shifting. It also has a performance mode that will raise line pressure across the board XX %. Fantastic piece of equipment.
On a 98 model 4L80-E the cooling outlet (hot) is up front and the return (cool) is in the back. Be carefull with the inlet, it must have the proper fitting installed that protrudes through the case and seals into the center support.
Everything will bolt up easily. The 4L80-E has ears on on the bellhousing for medium duty applications. With long tube headers these will probably have to be cut off. The rear support on the 80 is further back and higher that a 700R4, keep that in mind.
Im putting a 4l80 with full manual shifting into my car next week. I just had chris at Wicked Performance Converters build me a nice 3800 stall for it. Ill let ya know how it works out.
I am a little lost on the tailshaft with a fixed yoke. Do you have any pictures?Will there be any issues with a 9" rear-end u-joints?
I have fuel injection so I guess I can use the TPS on it.
I have a empty case that I will use to see how much work my tunnel will need.
I am looking forward to this. I have been through two 700r4's rebuilds and was thinking about going to a turbo 350 or 400.
With the speedpro can you manually shift why racing or does it shift by rpm set points?
Last one for now. Is there a dust cover for this trans? I assume it is and can be bought at local chebby dealer.
I am a little lost on the tailshaft with a fixed yoke. Do you have any pictures? Will there be any issues with a 9" rear-end u-joints?
My old 3.5" aluminum shaft is on top:
This is a 4L80-E with a fixed yoke:
