How trans brake works
Old Oct 27, 2004 | 08:54 AM
trtturbo's Avatar
Default How trans brake works
How does a trans brake work in a TH-400?
Also, what will a reverse valve body do for me.
This on a street driven truck.
Old Oct 27, 2004 | 10:13 AM
john kilgore's Avatar
Default tb
most tb's work by putting your trans in forward and reverse at the same time. when you let go of the brake button it falls out of rev and you are on your way. rev. vbs have no compression except 3rd. it is possible to make a rev. vb with a brake and compression braking. good luck
