Mostly Stock Cars w/ Converters: INSIDE
A lot of people have not believed my 60ft's on the tires in my sig the car will on the avg. pull mid to low 1.70's on all three tracks I run at in my area the track track prep. has to be good to very good. Almost forgot all my low 60fts are na.
With a lid,catback, ORY, pulley, tuning, and a SS3800 launching at only 1500 because my nittos were bald, I managed a 1.75 60' in the summer time. My car was also lowered without relocation brackets, so I want to see how things turn out now that I have them and its cold out.
Vig 3200, 3.23's, 26-8.5x15 ET Drags, 3550 raceweight, boxed lca's w/relocation brackets, rt side air bag, '95 Camaro V6 rear springs, stock rear shocks, stock front springs & shocks, front swaybar disconnected. consistent 1.67 sixties. (stock motor-'02 w/just ASP pulley, FTRA, LS1 edit tuning,through stock exh manifolds, Mufflex OR pipes and cutout) 12.32 @ 109. WJ.
Best I've done so far with the Vig3600, is a 1.707" 60' with big a$$ BFG 315/35 drag radials at 14 PSI, approx 3834 lbs w/driver, (3/4 tank) 7.932" 1/8th, 12.483" @ 108.35. I could only do a fast walk off idle then hit it after I get moving. I was in "THE MINE SHAFT" that night, (52 degs, 45% hum) at Atco Oct, '03. IMO, big 17" drag tires have too stiff a sidewall too really hook off the line. I'm jumping on the ET Street express with some 26"x11.5"x16"s on some chrome 16"x8" ZR1's. Hopefully, this will let me flash from idle and get me and the SS Titanic, off the line in 1.6x too 1.5x seconds. I'm done with drag radials, cause I'm done playing. Tom is turning 12.2's with a Vig3200 and a cam on BFG's and has seen a 1.6x 60 already.
He's making me look bad
. Just kidding, Tom
. I'm steppin' up the pace for 2005, but I'm still not doing a cam, heads, or headers. I like my quiet, little car, err destroyer, (as in boat!!). Besides, I ALWAYS have a few tricks up my sleeves.
. Just kidding, Tom
Freemods,Lid,ST3500,LCA's,relocate brackets,RRairbag,stock shocks/springs,!frontswaybar,26X10.5X15 ET Streets & skinnies on welds, AT catback, 3450lbs, 3.23, consistent 1.65 60's 12.49 &110 lifting the left front. Stock manifolds, cats and Ypipe.
