how important is tranny cooler
Old Nov 1, 2004 | 06:03 PM
Blue02z28's Avatar
Default how important is tranny cooler
I have a Vig 3200 stall... but dont have a tranny cooler, how important is it?
Old Nov 1, 2004 | 06:17 PM
SmokingWS6's Avatar
The quicker you can install one the better. Heat causes around 90% of transmission failures. they run about 40-60 bucks, a lot chaper than a burnt trans. They are fairly easy to install and well worth it. It was the first mod I did to my car, long before I had my converter. In addition, you might consider the deep trans pan. It holds a few more quarts of trans fulid and has cooling fins to help keep it cool.
Old Nov 1, 2004 | 06:21 PM
Blue02z28's Avatar
ok, from where i have read at Vigilante's website, they recommend one for a NON lockup torque converter. Mine is a lockup torque converter, so is it still bad that I dont have one?
Old Nov 1, 2004 | 06:57 PM
BADFNZ's Avatar
Get One!
Old Nov 1, 2004 | 07:33 PM
SmokingWS6's Avatar
get one! the converter is only locked up while your curzing on the highway for the most part. Stop and go city driving, racing ect its unlocked generating a fairly large amount of heat. 200+ degrees is considered the danger zone for transmission temps, and some people even with transmission coolers reach 200 degrees.
